64 SRT8 Dart
Srt8 dart are you skilled in the art of spray transfer mig welding? Can it be done on a 110v welder because I use to be good at it with our old 220v but can't seem to get the transfer right on the lower voltage welder.
Hi johnparts, yeah, I've used that process many a times. Some customers products require us to use that process...for whatever their reasons are.
We use an ER70S-6 .035" hard wire usually paired with 95/5 Argon/Carbon Gas mix. The perimeters are I think 22V at the lowest to run, otherwise you start just running back into a globular transfer. We usually run it around 24-26V's which if I recall is around 260-280amps, just depends on wire speed. I'm not sure a 110v welder can push the amps needed for that kind of transfer, what kind of gas(s) have you tried?
You can also substitute with 85/15 Argon/Carbon and have the best of both worlds. Run it low for more of a globular transfer and run it high for more of the spray.
For those who are somewhat beginners, Argon helps put heat into the part and takes care of alot of spatter. A straight carbon gas gives you alot of spatter but doesn't run as hot. The mix is what helps the weld look nice and perty, gives great penetration, and less spatter.
