Well Well, Oh Well....
General Discussion
  1. dartfreak75
    dartfreak75 Restore it, Dont part it! FABO Gold Member
    10,787
    8387
    Aug 10, 2011
    Virginia
    Local Time:
    5:51 PM
    Buy a winch they are cheap. Don't kill yourself trying to pull it like that
    • Like Like x 1
    • Agree Agree x 1
    • RustyRatRod
      RustyRatRod I was born on a Monday. Not last Monday. FABO Gold Member
      78,033
      55599
      Jun 7, 2010
      Georgia
      Local Time:
      5:51 PM
      How will I power it? It's over 100 feet from the nearest outlet. It will trip breakers comin and goin. Get a 12V? Yeah.
    • RustyRatRod
      78,033
      55599
      Jun 7, 2010
      Georgia
      Local Time:
      5:51 PM
      I'm not tryin to shoot down ideas, but this is a pretty big pickle for us. lol
      • Agree Agree x 1
      • dartfreak75
        10,787
        8387
        Aug 10, 2011
        Virginia
        Local Time:
        5:51 PM
        Battery on your truck they hook right in i had one on my 4 wheeler
      • Ironracer
        Ironracer Gearhead
        1,487
        992
        May 8, 2020
        Tampa Bay Florida
        Local Time:
        5:51 PM
        I have a 100' big ass cord I' could mail ya.. 10ga...or rig a 100' roll of Romex, as a temp supply
        • Like Like x 1
        • RustyRatRod
          78,033
          55599
          Jun 7, 2010
          Georgia
          Local Time:
          5:51 PM
          How long will it go without overheatin? Do they really work that well? I may look into it. I do have a Harbor Freight card. LMAO
          • Like Like x 1
          • dartfreak75
            10,787
            8387
            Aug 10, 2011
            Virginia
            Local Time:
            5:51 PM
            I understand im just giving ideas I don't want anything bad to happen to you or kitty. Don't want you or her getting hurt trying to pull the thing.
            • Agree Agree x 1
            • dartfreak75
              10,787
              8387
              Aug 10, 2011
              Virginia
              Local Time:
              5:51 PM
              The one I had on my 4 wheeler would pull a 4x4 polaris 500 out of damn near anything I got it stuck in lol
            • AUSA66
              AUSA66 Well-Known Member
              246
              324
              Nov 20, 2014
              Perth
              Local Time:
              5:51 AM
              I would check before pulling it up must be a sizable pump to push a 350 ft head of water should be an overload on the supply breaker check the setting will give you an idea of what size motor is down there you could also check to see if it is drawing any current will help to tell if the well is dry or the motor is kaput
              • Like Like x 1
              • Agree Agree x 1
              • RustyRatRod
                78,033
                55599
                Jun 7, 2010
                Georgia
                Local Time:
                5:51 PM
                If I only knew how to do "ALL THAT". lol
                • Thanks! Thanks! x 1
                • AUSA66
                  246
                  324
                  Nov 20, 2014
                  Perth
                  Local Time:
                  5:51 AM
                  Do you know if the pump is single phase or 3 phase also do you have access to an amp tong that measures AC .
                  Does the pump have a starter box with a red & green button or is it fully automatic & start when you turn the tap on.
                • RustyRatRod
                  78,033
                  55599
                  Jun 7, 2010
                  Georgia
                  Local Time:
                  5:51 PM
                  It has a pressure switch similar to an air compressor. It's automatic. All this is single phase. I've checked for power AT the well and it has power to each leg. All that's left is 340 feet straight down, so either there's a break in the electrical wire, OR the pump is bad. Either way, it's gotta come out. It's about time I guess. We've been out here 20 years next year.
                • AUSA66
                  246
                  324
                  Nov 20, 2014
                  Perth
                  Local Time:
                  5:51 AM
                  20 years that's a good run.
                • eekvonzipper
                  eekvonzipper My Member is Legendary! FABO Gold Member
                  697
                  558
                  Apr 18, 2020
                  Cadet, Missouri
                  Local Time:
                  4:51 PM
                  Well Fuq... What's the Answer? It would be Really cool if about Forty Mopars showed up at Your place this week to get this thing runnin' again. Hmmmmn
                  • Agree Agree x 1
                  • RustyRatRod
                    78,033
                    55599
                    Jun 7, 2010
                    Georgia
                    Local Time:
                    5:51 PM
                    LOL
                  • RustyRatRod
                    78,033
                    55599
                    Jun 7, 2010
                    Georgia
                    Local Time:
                    5:51 PM
                    It is. We are very blessed it has lasted this long.
                  • pauly
                    pauly MOPAR or no car! FABO Gold Member
                    2,493
                    1304
                    Nov 1, 2012
                    Holton, Michigan
                    Local Time:
                    4:51 PM
                    Call the well driller? Not gonna be cheap, but easier on your back. My well pump died on me about 5 years back. Mine was only 47 feet deep and PVC but the pump was stuck in the bottom. It did come loose but driller told me he has seen many of them rust off and fall to the bottom of the casing or get stuck in the casing. He had a big A frame on his truck.
                    • Like Like x 3
                    • famous bob
                      famous bob mopar misfit
                      19,852
                      8827
                      Aug 14, 2011
                      okla
                      Local Time:
                      4:51 PM
                      sucks , I remember helping to pull a 160 ft well to change the footvalve , that wasnt even fun , good luck !
                    • CFD244
                      CFD244 FABO Gold Member FABO Gold Member
                      1,045
                      1010
                      Sep 7, 2017
                      Northern Ontario, Canada
                      Local Time:
                      5:51 PM
                      For some things, you've just got to call a pro. That's my game plan for when it happens to me.
                      • Agree Agree x 6
                      • qkcuda
                        qkcuda Well-Known Member
                        1,546
                        1644
                        Mar 6, 2013
                        Jarvis, Ontario
                        Local Time:
                        5:51 PM
                        The wheel rim post gave me a dumb idea. Could you use an old wheel rim welded to a pipe on an A frame as a roller, and then loop the pipe over it and pull it out with your truck or tractor? Converts the vertical motion to horizontal. The A frame would have to be WELL anchored to keep from toppling over.
                        • Like Like x 1
                        • Agree Agree x 1
                        • red67gts
                          red67gts FABO Gold Member FABO Gold Member
                          2,193
                          991
                          Apr 14, 2009
                          Coker,Al
                          Local Time:
                          4:51 PM
                          if you have a neighbor with a tractor with loader that you could attach one of the pulleys on chain to or maybe construct a sturdy A frame to attach pulley to over the well then run a rope or cable over the pulley then tie it to truck and pull it out that way. The higher you can get pulley the better so the the pipe will bend without kinking. I have had to do it before, good luck
                          • Like Like x 1
                          • diymirage
                            diymirage HP@idle > hondaHP@redline
                            25,710
                            23522
                            Oct 12, 2012
                            michigan
                            Local Time:
                            5:51 PM
                            Is there enough of a foot print there to safely set the cherry picker down?
                            Maybe you can use that as a frame and run a tackle block from it, then pull it out with a truck
                            You mentioned not having 110 for 100 ft...could you tap into the feed to the pump itself?
                          • red67gts
                            2,193
                            991
                            Apr 14, 2009
                            Coker,Al
                            Local Time:
                            4:51 PM
                            whatever you attach pulley block to needs to be sturdy so that it doesn't flip over when you start pulling and I would be afraid the cherry picker would turn over
                            • Agree Agree x 1
                            • RedFish
                              RedFish Well-Known Member
                              25,292
                              3627
                              Sep 5, 2007
                              Local Time:
                              4:51 PM
                              Call the man! Mine was a shallow well set up. 2 pipes going down to injector at 63 feet. When the foot valve failed the pipe would drain as I pulled it up but it was a slow go and still heavy. I could do it back then but wouldn't be able today.
                              My neighbors well was like yours but only 210 feet deep. Lightening would kill that pump and the wire once every 2 years average. You've been lucky.
                            • red67gts
                              2,193
                              991
                              Apr 14, 2009
                              Coker,Al
                              Local Time:
                              4:51 PM
                              Neighbor across road had well drilled and was cased with PVC pipe. Lightning hit hit and destroyed it. The well pump company could not pull pump out with their special truck. Turned out when lightning got to water level it shattered the casing and had to drive another well beside it with new pump and all
