What do I need/ options for efi crank trigger, stick 5.2 Mag?
67Dart273
Idaho
Found an older 3/4T with bell/ flywheel/ clutch/ 4 speed, was thinking of putting into the 97 3/4T "White Whale III" now is an automatic.
What would I have to do with an older flywheel to trigger the factory EFI?
Is it as simple as buying a magnum flywheel, but don't know what a 70s--early 80s flywheel ?? would match for the starter mount, etc?
Or aftermarket front mount trigger wheel?
I believe the magnum uses a 143 tooth flywheel. I purchased a flywheel from Brewers for my 5.9. You may be able to use a crank trigger on the front of the engine. I'm going to use a Megasquirt on mine.
I also talked to DionR and he thought they were 143. If so, it should be a "bolt in" after notching the bell
