This morning I removed the guage assembly from my 65 barracuda to replace some bulbs, the voltage limiter and clean the contacts to the lights. When I put it back together everything is dead. I have a red wire a black wire and a plug that has 8 wires. The red wire has voltage. Nothing else does. I have no lights or no power at the ignition switch. I have taken it back out 3 times double checked the wires and put it back in place with the 4 screws to ground the unit. I didn't replace the voltage limiter as of yet.
Any ideas,
Must be a loose wire. The nut connections are tight but I was checking for voltage at different point and everything came on. So now I'm checking wires
Any ideas,
