What Head to use on 360 Stroker
joes68340s
Rescue CA.
Im building a simple 360 stroker, want a good street motor, with a mild cam. What heads have people been using. Thanks
magnum heads might be good for you. ported and you get the 1.6 ratio rockers to boot.
sb
If you have the cash, the RPMs are my first choice all around wise. I've built with irons, but good prep runs close to the cost, and you still have iron heads weight wise, and in most cases, an open chamber. Magnums or Magnum R/Ts wouldnt be bad, but std Magnums may not move eough air for decent numbers above 5K rpm in most cases. So first choice, the closed chamber RPMs.
Im leaning towards the RPMs. I would like to run Econo W2 heads but these are to hard to find. Thanks
I'm running Edelbrock RPM heads on my 410". I can't complain about the performance though I don't have an even comparision to know what the gains have been. I ran them stock for about a year then had Hughes Stage II port them.
