I have a '73 Scamp no engine or transmission that I traded a runnin and drivin S10 truck for. It all depends on how badly you want one. Places to look for rust are under that vinyl top all along under the rear window and in the rear window lower corners. the front floor pans because the wiper shaft seals are notorious for leaking and rusting the floor pans out. The rear quarters down low from where the rear window may have been leaking into the trunk extensions. Also, these cars are all notorious for rusting at the factory seam at the top of the quarter panel where it joins the roof. Whether there's bubbling or rust there or not, I would take it all the way to the metal because it was poorly prepared at the factory since it has a vinyl top. Now, all that sounds bad, but rarely do these cars have ALL those problems. It may actually be a solid car.....mine is.
