myasylum
Awhile back I was reading that with the Crane Iron rockers and the stock 273 rocker there was a oil trick you could use for better lubrication. I know where you are suppose to drill the hole, but what do you use to fill in the top hole? Do you weld it shut?
Suppose you did this to every other rocker, so oil would flow from both directions, is that a option also?
Could someone explain this theory to me?
Thanks much!!
Thanks much!!
