what is this component in engine bay?
fishyfish36
Active Member
Phoenix Arizona
Need help Identifying this component, It is not connected to anything at the moment and I was wondering if it was critical. thanks
That is an owner or dealer added A/C system or parts of a system.
that is not the factory location for that. And you can see the wonky brackets
I thought it might be an AC component considering that hardline ran towards the front in front of the radiator and went to nothing. I'm removing it now should I hang on to it or toss it? a quick google search has them new ranging from 15$ to 90$ . I won't have a use for it thats for sure.
toss it.
not factory lines or routing like the others you see for sale. The driers are typically re-used.
Dryers are trashed when left open to the atmosphere.
You can also remove the conduit clamp just above the heater motor
From what I can see of your engine compartment it seems rust free in the seams.
You might want AC in AZ. Search for the long post on compressor options for a slant six. If you run across a 1977-78 Volare/Aspen slant in the nice junkyards of AZ, see if it has a Sanden compressor. If so, grab those rare brackets.
thanks. I dont plan to put it back into the car at this time with my current build plans. I have a daily driver for some comfort. heat is bad out here between June - October
