It for bending back and re-crimping the plastic tank retaining tabs on aluminum radiators.sheet metal nibbler
That’s not what it is but it sure looks like one.View attachment 1716011989 Neat thing about this one is that it doesn't distort like shears do.
Same handles anyway. It's possible a different jaw was added for crimping radiators. It looks like it has that strange hook jaw.That’s not what it is but it sure looks like one.
Notice the depth adjuster for the crimp. Just an offset square.Same handles anyway. It's possible a different jaw was added for crimping radiators. It looks like it has that strange hook jaw.
Wonder where I can get Phillips and standard screw bits for it.Hand Drill
Are the drill bits in the handle?Wonder where I can get Phillips and standard screw bits for it.
You loosen up the knob about mid way down the body and slide down the handle to expose the drill bits, they are a special bit with a flat ground on one side.Are the drill bits in the handle?
No it's a Yankee hand drill.That’s a yankee screw driver
Bummer. I have a drill and a screw driver around here somewhere. Basically the only difference is the driver is reversible. Cool toolsNope, no bits in the handle.
For what Pete?Cut it off
The other one is a valve keeper holder for when you're assembling your cylinder heads.The other one will be a hard one. I was stumped actually on it.
YesThe other one is a valve keeper holder for when you're assembling your cylinder heads.
I had a reputation for fixing those types of columns,did them all the time. Not many guys around here would touch them. And its better to have it and not need it than need it and not have it.Yup. It might be in my drawer of tools I hope I never need again. Lol. Might need a bigger drawer for those tools.
