Thanks..!That would be for the battery cable where it goes down to the starter.
Thanks..!It should be rolled against the firewall capturing the brake line. The closed around the cable with the gap towards the column.
Alan
That green stuff looks like weedeater string!What is this for..? Wire harness..?
Anyone have a pick of what goes in that...factory pic..?View attachment 1716336361
What year is that on?It should be rolled against the firewall capturing the brake line. The closed around the cable with the gap towards the column
My references are 67, all four 67 that I have (had) are the same.What year is that on?
Mine's a 67 and I replaced the batt wire. The oe part was held as you see in my photo.
