I respectfully disagree. Cone type sure grips are not rebuildable. To rebuild something basically means your making it new (or close) to new again. If the cones aren't worn down to stubs and/or the case isn't all wollered out you can chuck the cones up in a lathe and cut some of the end off so they don't bottom out and they'll work for a while again. There is no process whereby you can resurface the cones or the case to make them like new again. I have seen several of them that were IMO junk. You could have cut the cones down so they'd grip for a few thousand miles again, if you didn't run them too hard, but that's it. No where even close to what I consider "rebuilt". Only clutch types are truly rebuildable
