What oil filter?For a 360 in a 66 Dart
pettybludart
Ontario,Canada
I,m putting the 90 degree oil adapter on my 360 that,s in my 66 Dart.Which oil filters are used(big or small)?I,m running Spitfire headers.Any #,s or advise thanks.I already have a new gasket set(3) for the adapter.
I run a fram 3600 equivalent on my 64 Dart w/hooker 5208's...
They are as long as a PH8A but not as fat..
Bob
Run from fram..... get a shorty Wix. Either a 51068 or 51085. If you go to Napa or Carquest, drop the first number. Best filters for over the counter.
I always run the longest filtre that space will alow.The bigger the filter more dirt that is trap.
I ended up getting a XG16 synthetic filter(Fram)I,m running Royal Purple synthetic oil in the 360.It,s a fresh rebuild,so I figured I,ll try thr synthetic this time to see how it is.Thanks for the suggestions!
I sure it has been posted before but there is a group buy over on Moparts for Wix filters. I just received my 3rd order from it. Wix #1085 for $3.79 each.
Sorry to hear you bought Fram......
NAPA and CarQuest filters are Wix; if it says "Affinia" or anything about Gastonia, NC it is a Wix. Affinia bought Wix from the Dana Corp a few years back. Wix is the best IMHO- 51515 should fit w/a 90 degree adapter
On the left is a Fram PH43 with 5 1/8 mile passes on it. On the right is a brand new PH43. I just put my 360 back together and after the first pass i had 15 psi at the end of the track. i had heard horror stories about Fram filters and paid no attention, I now listen to what some people have to say. Take it from me that Fram is prolly not the way to go. I now have a K&N HP-2004.
Sorry?What would you recommend??
As stated previously.....
and....
That last pic should be one of many that you will see about fram.
