what oil pan to use????
I had the milodon 7 qt oil pan for my 340 but I returned it because they came out with the road racing oil pan. Talk to AutoX he can tell you more about it.
I've got two kevko pans. The welds aren't pretty, kind of ropey, could have put more voltage/less wire to them to lay out flatter, but they are solid.
good info, thanks! also, were yours supplied with scrapers? and are you running a windage tray too?
Has a very basic scraper installed on vertical wall. I don't run a windage tray.
I run the Kevco 6 quart. Yes welds aren't pretty but no leaks and I have never heard of any of them leaking. Great ground clearance and zero notching was needed. And its 6 quarts plus what ever the oil filter uses. No windage tray needed either.
