I keep hearing straight 30 weight? whats this mean 10 w30
Maybe I can clarify this for you. 10W-30 act like a straight 10 weight oil when cold and a straight 30 weight oil when hot. 20W-50 acts like a straight 20 weight oil when cold and a straight 50W oil when hot, etc.
Cam manufacturers used to reccomend using a straight weight oil when breaking in the cam back in the day. Their reasoning was that multi-viscosity oils require additives that modify the flowability (viscosity) of the oil and those additives don't help the anti-wear properties (lubricity) of the oil. BUT, in a street car that has to run in a gamut of tempratures, the need for multi-viscosity oil overrides the minor loss of lubricity.
If someone were to run 20W-50 or straight 40 or 50 weight oil in a tight bearing clearance engine on a 10 degree day, the engine would eat it self up on start up. That stuff turns to syrup on cold days and I've seen people sieze a valve in the guide doing this exact thing and sure enough, in a less than a year they have to replace rod and main bearings.
On the other hand, in a loose clearance racing engine running a light 10W-30 oil is a bad idea. The oil film is not tough enough to withstand the high heat and pounding of the rod and mains.
The 0W oils are really for super tight clearance new engines. They have very low pumping losses and increase hp output and help with fuel mileage at cruise.
There is a school of thought that running a loose racing engine with a HV oil pump and the new synthetic 0W oils will reduce windage, pumping losses and still provide the oil film toughness and lubricity needed to prevent the engine from self-destructing. I can't comment on that as I've never tried it but it make sense.
The zinc additive thing is a whole different thing and has been beat to death here. Let's just say that it is no longer put in most oils, if you are running a flat tappet cam you have to have it whether it's a poured in additive or blended in at the factory.
Having said all this, I use 10W-40 in the summer and 10w-30 in the winter in all my flat tappet tight clearance street engines. In the loose clearance engine I'm building now, I'll run 20W-50 VR race only stuff. I prefer Valvoline in all my engines and use the Hughes Engines additive only because I can't find Valvoline VR locally in the weights I want.
I hope this answered some of your questions.
