What Rims with a Wilwood on a '65?
J Glenn
Minneapolis
I'm trying to figure out what rims work with the Wilwood brake kits (mostly because they have that funny oversize 'dust cover' in the center.) I like the Torq Thrust D's (15") but I don't think they'll fit.
Wondering what 15" rims people are running with Wilwoods on their early A-bodies.
GO....
You might post a picture or two & take some measurements of the diameter & length of the hub. Someone here can probably use those measurements on their Torq Thrusts & tell you if they will fit.
It would probably be easier/faster to just measure those hubs. Then go to the wheel manufacturer's website. They almost always show that hub bore size in their specs.
You might post a picture or two & take some measurements of the diameter & length of the hub. Someone here can probably use those measurements on their Toeq Thrusts & tell you if they will fit.
Excellent IDEA!
The biggest concern is the 3.24" center hole requirement. I mean
Looks like you can use a wheel with a (minimum) 2.500" bore, as long as it has a 3/8" chamfer on it to clear that big radius.
