hey guys i am buying a set of KB pistons part # KB 400. Should i get the kit with the rings or get the rings seperate? If so what rings should i get? I know i will need file fit rings. The engine is a 383 4 speed and will be street driven. Thanks
No reason not to get the rings with the kit if you can save some dough. Just make sure they're moly faced.
Pretty sure in the kit only the top ring is moly faced. And for some reason in the kit the rings state "no" for fill fit. Can they still be filled? Thanks
Looks ok. i disagree with the bearings especially given the polished (not cut and polished) crank surfaces but that's just me.
Also - "decking" the block will not mean it's square (parallel to the crank centerline and perpendicluar to the bore centerline). It will mean it's been cut to flatten it. You need to have a shop "square deck" it an in order to do that, the shop needs the right fixture. So if your goal is to "square up" the block you should make sure you knwo what you're looking at in terms of equipment, and ask to see it. Many shops say they square deck and charge appropriately, but can't because they don't have the fixture.
Also don't forget you'll need to file fit the rings per KB's instructions.
All that matters is you're happy with them.
