Cleveland57
I guess this could have been posted in the "newbie" section, but I figured I would cut to the chase - I need help and/or opinions with an engine rebuild.
First, a little background: I picked up my 1969 Dart (/6, 904, 7-1/4)about 2 years ago for a daily driver, immediately put on new leaf springs, shocks, brakes, tires and wheels.
With my wonderful wife's support, I decided it was time for some upgrades. I picked a B-body rear (3.31/489) which I had narrowed and a 360 motor with the matching 727 trany. My goal was to gather all the running gear and then after body and paint work, re-assemble the car with the new pieces.
I'm not the most automotively inclined person. I know what I like more than I know how to build what I like so unfortunately I need to open my wallet to accomplish my ideas. But I did choose (via a friend of a friend of a friend) a reliable engine guy at a reputable shop to do my rebuild. I told him I wanted to increase the stock 360 motors HP and I wanted it to have an aggresive growl.
Here's where my story gets muddled.
Despite my automotive inadequacies I wanted to be involved with the build (with the builders approval) and maybe learn a thing or two. Long story short, I was told the engine was done without my input or knowledge of what was going to be used to put it back together. I asked for a list of what had been done and this is what I was provided with:
360 motor now about 365 ci
.060 Bore
.020 Rods
.020 Mains
Hot Tank - Bore - Hone
Turn Crank - Balanced
3 Angle Valve Grind - New Seals/ Guides
(replaced bad valvesand seats)
Replaced Bent Flex Plate
New Soft Plugs
All Parts Hot Tanked And Cleaned
9.5 to 1 Hyper Connetic Pistons
480 Lift 230 Duration Crane Cam - Bearings
Melling High Vol Oil Pump
Progear Double Roller Timing Chain
Fireseal Gasket kit(engine)
Engine Tech Rings/ Bearings
Most of that is gibberish to me but I typed it exactly as it was given to me. I already have the Edelbrock Performer intake and stock cast 340 exhaust manifolds and plan on adding Flowmasters. I'm looking for a cruiser not a race car. My questions to anyone willing to answer is:
Does this sound like I'm on the right path as far as power and sound?
Keeping budget in mind, do you see any areas where I might want to improve performance?
Ballpark, how much should this cost me?
And one non-engine question - manual steering vs power, pros and cons?
I appreciate any and all input
Thanks!
.060 Bore
.020 Rods
.020 Mains
New Soft Plugs
Thanks!
