B3422w5
If the rockers hit the springs, you need to fix the rocker geometry. You can run at least a 1.550 spring with the geometry correct before you need to offset the shafts.
Harland Sharps wont clear any bigger than a 1.50 spring on Eddie Heads. That per Dwayne Porter@ PRH
I know i have 1.46 trick flow springs on my eddies with HS rockers. Dwayne specc’ed them for me. They work with a fairly aggressive flat tappet i use very nicely.
