What size rear Wheel Cyl.? K/H conversion.
one mile
Taylors, S.C.
I have all of the system pretty much figured out but the rear cyl.requirements on my daughters '65 Barracuda. K/H up front, right prop. valve all new lines, new Shoes and hardwear on 7 1/4 rear but the size I should run on wheel Cly's has come into question. Any thoughts on this ? Going to be her D.D. but she will AutoX it a little if I can get her mother to O.K. it. You know how it is.... Any input is welcome. Thanks, Tim
If you want the braking to be balanced go with 7/8" rear wheel cylinders. Order for a '72 Dodge D100 truck 2 WD rear wheel cylinders.
still smokin it over, what I have seen here most Posts like 7/8. I will go with the 7/8 and put an adjust Prop. Valve if that does not meet my needs. Thanks you guys for your inpuit, Tim
