DodgeLad
Skipped the Light Fandango
Was 32* today and nothing. I checked the actuator with vacuum and it works. Thinking the thermostatic switch mounted in the air cleaner doesn't work right. It's a 1980 truck with a Holley 1945.
Not sure which way you mean is 'open' in your description... more heat from the heater shroud, or more cold air from the snorkel? The way this should work is that:Checked it this morning. Mid 30s outside. After starting and at idle, the flap was *slightly* open. I revved her up using the throttle cable and the flap opened up the whole way. Let off throttle, the flap closed some to the slightly open state. Results could be repeated.
Unless someone thinks otherwise, I believe it is working exactly like the manually states.
I think I need to play with the choke adjustment some more. It's a third party electric choke. Feel free to school me on that adjustment.
Thanks again
