fishy68
Tyr Fryr's Inc.
There is an adjustment inside the tranny to increase the pressure without having throttle travel interference. It has been a long time since I was in an automatic tranny but I believe there is an allen bolt adjuster below the servo.
There is an adjustment for the main line pressure and it shouldn't be adjusted without gauges hooked up to the line pressure and servo pressure outputs then going through the sequence described in the factory service manual in which to test/adjust it. You can blindly crank it up but you never know how much affects it and if you go too much it'll start popping seals or cause overlap between gears which is bad. I recommend installing a Trans-go shift kit before cranking the pressure up.
Thanks Blownfish, I'll look into that, although for now I've orederd the proper linkage Chrysler linkage for the Holley.
Fishy:
There is really no way to get the transmission to behave the way you've described, that is exactly how I have set up the last 3 Mopar transmission I've done, even TH350 chevy's are the same... the trans just doesn't respond. I think/hope the linkage has too much travel for a Mopar, looks like it's the Ford linkage that's on there...
Lunati is a cam I've looked into and it interests me, I just like the name, especially the Vodoo series. I've heard good things.That may be the problem, wrong linkage. And it may also just be a slpppy shifting trans. that a shift kit will take care of.
I want to play with the timing when it stops raining out, where is the allen head to adjust the vac pod located?
Thanks
David
Yeah the Voodoo series are the aggressive ones. I run one in my 360 and it runs great. The allen head for the vacuum advance adjustment is accessed through where the vacuum line plugs onto the vacuum advance. Just pull off the vacuum line and stick the proper size allen wrench in it. But that only adjusts how quickly the vacuum advance comes in. It doesn't affect how much timing it has or how fast the centrifugal advance comes in. The only way to affect the amount of advance is to modify the weights in the dist.
