srixon4406
TURBO TOAD
Let me first give you guys a little run down on the car its a 62 valiant /6 turbo I'm planning on running a 833 OD trans with a 8.75 rear end
I'm in the process of moving the rear leaf springs inboard 3 inched and my problem is I'm not sure of the combo I want to run here are the options I have
1 super stock springs
2 caltrac setup with the SS spring
3 slider setup for the rear shackles or the standard shackles
4 pin snubber
5 drag shocks
If you had these options to choose from what combo would u select and please let me no why I have hopes of getting this car in the low elevens high tens and I have all the parts mentioned above
thanks
Aaron
4 pin snubber
5 drag shocks
thanks
Aaron
