I am just taking apart the old 318 that was on my dart before I swapped in my 360. The 318 ran fine but burnt some oil. As I started taking it apart I started to see that it wasn't the original engine, it's a 84 with a roller cam. The top of the motor was perfect looking, nice and tight, the cam and lifters were in really good shape too. The heads looks pretty good, but two cylinders looked odd, one on each side.
I started taking the Pistons out, the bearings all looked brand new still, and the cylinder walls didn't have a ridge or anything on them. Upon taking the Pistons out everything looked good, except two of them, pieces of the rings fell on the floor for both of them, explains the burning of oil.
What would cause this to happen? And what type of Pistons did a 84 318 have? This one has flat tops and they don't seem to sit very far in the hole. They also all had a very small notch in them on the side, does this serve a purpose?
