What's behind the stock speedo?(non-ralley)
magnumdust
cali
I know a few people have gutted their old gauge clusters to make custom gauge pods. Is there anything there that will affect the other gauges/lights?
My oem speedo doesn't work(shakes at speed/isnt accurate) and i'm not in the mood to mess with lubing the cable/changing the speedo gears to accomodate the tires(which will change frequently). On top of that i'm just a little more involved in getting my car to run/handle right.
So i was thinking tonight that maybe i could gut that speedo section of the stock cluster, buy a GPS speedo, and make a cheap plate to mount it on that gutted area for the time being and retain the oem gauges that work.
Obviously not an aesthetic or permanent setup, just until i get around to buying the other gauges and buy an insert.
It would be less work to just clean and lube your original.
If you really want a temporary GPS set up, just buy some velcro tape and stick it over original speedometer cover.
No reason to drive around with a butchered looking dash.
