elvaliant66
Was driving my 67 valiant at night hit a bump then suddenly my headlights were flashing as if they were hazard lights I was trippin out!!. As I looked at the dash I seen a wire glowing red hot and smoke coming out under the dash .i turned the car off immediately.i waited a bit then turned my ignition switch on and tried my turn signals they worked no problem ,brake lights worked and headlights also.so I started it and drove home.next day I checked under the dash and it was the black wire to my signal flasher connector.traced the wire and there's 4 wires spliced which is a pink one (wiper switch) black one (ignition switch) and the flasher (black wire) to another black wire. Is that factory splice? They did a good splicing job but not sure if all 4 wires can be joined like that . I haven't done any electrical to it. I bought the car about a month ago it's been my every other day driver for about a month. only drive about 20- 30 miles a day . Any help is appreciated thanks in advance!
