j par
Well-hung Member
What are they good for ? And what are they bad for? How do they work?
They are good for taking your money. Every person I know of or heard of that ever used them had trouble with them.
They are good for people who can't afford to prep a cylinder or an engine like Pro Stock does.
They are a bit bad for your wallet if you are on the scotch side. Or, you run an .043/.043 ring pack (or thinner) and gas ports and a vacuum pump.
Other than that, I'd have to type too much.
Well that's what I have on now as they came with the stroker kit. I was wondering if they make any difference over I guess a standard piston ring. My concerns are Further that I'm thinking this winter I may throw up to a 150 shot at the car For Kicks....
Scotch is what you DRINK.
A scot.
The Scottish.
He is a Scot.
They are Scottish.
And... "I'm so cheap with my money because it's so damned expensive!"
I've probably used 100 sets.
I've said this before, but I'll say it again. I hooked a blowby meter (just a simple manometer) to a 400 Chevy that no matter how well the bore was prepped, it would bury the meter 1.3-1.5 seconds into the dyno pull. You could watch it build pressure from the hit. If you made a long enough pul it would eventually hit 12 inches on the gauge.
Swapped in the Total Seal gapless tops and no matter how hard you pulled on it, it would never go more than 2 inches on the manometer. I tested a couple more engines that were less prone to ring seal issues but I always found better seal UNDER LOAD with the gapless TOP rings. Use them in my engine that I may stick in the hole today.
Done correctly, any ring will seal. Depends on what you expect, how you evacuate the crankcase, how you finish the bores and a couple other things.
If your Total Seal rings didn't work, find a different machinist.
BTW, gapless second rings have been around for long before the gapless top. That ring set has some issues. Gapless Top ring technology was done because the Pro Stock, Comp, and I assume ASScar guys were ESSENTIALLY running gapless top rings so Total Seal found a way to almost duplicate what costs thousands of dollars to do...run essentially a gapless top ring. Either way, you better have your second ring correct, or the top will unseat under load.
I can't give away all my secrets LOL and by the way I'll be at t&t tonight in case you can Band-Aid that junk together. Oops I meant slow junk...You get the kit from Kenny??
And this can be seen on Rusty rat rods guide to thread Hot Rodding mediocracy LOL [/QUOTE][QUOTE="RustyRatRod, post: All I wanna do at this point is have a little fun on the street with my limp member.
Well I can only take that as a compliment and yes I believe Triple R is in his early fifties. Ironically I'm out here given everybody s*** this morning and getting compliments? lesson learned....It goes away REAL quick.
WTF???. No offense but I thought I saw a pic of RRR and I thought he was in his 50's. Maybe it wasn't him with his straw hat on.
I don't wanna start too much.......since we have been gettin along SO well. lol
