Whats the Power Steering Belt Routing Circa 1965?
dibbons
La Paz, B.C.S., Mexico
Putting things back together ('65 Barracuda) after three years and the belts and pulleys aren't lining up. The factory A/C is all missing, of course.
Which means the alternator is "hodgepodged" on some non-factory brackets, so let's start with just the factory power steering pump.
Does the factory P/S wrap on the water pump or just use the one belt and crankshaft groove all for its lonesome? Thank you.
Factory P/S always had its very own belt.
A/C and non-A/C engines used all different brackets and pulleys. You can't mix and match and get things to work properly.
