68'barracuda
Unknown on state of engine, was running 6 months ago
3/4 ton is nice, looks like someone converted it to dual master, its got a hydraulic clutch, looks like there's not much body rot. Like said above, check the cab mounts, it looks like it's sagging. As it sits, being it's a 4x4, I'd probably give $2000. Maybe just my opinion though.
Second
Thats a 67 with dual master cyl and pie tin headlight rings it has lower gears for the slant 6 so its not so bad to drive and it looks to be in good shape body wise
You most likely have never owned a pre 71 dodge truck.
The problem is sweptlines really did not rust out on the outside so they all look decent.
The issue is what everything is attached to does, especially the cab, which by one, photo from the passenger side shows, the cab mounts front and rear are rusted out/ shot.
The door which is bolted to the rusty cab is sagging until it hit the rocker panel, cowl rusted bad.
This is a parts truck, it may run good but rust is rust.
The old gal is sagging more on its side than most 60 yr old women are in the front.
