These came out of a 13-1 iron headed small block. They have break in plus a couple 1/8 mile passes on them. Pistons and plugs looked great. They are Competition Products severe duty valves.
Did you see the valves when they were new? I've never seen detonation do that to a valve. The piston would be done long before the valve. I could be wrong because I haven't seen everything.
That looks to me like the machining on the valve was done with a dull tool.
were there any additives added to the fuel tank?FWIW... a good read below. Never heard or read of the valves being pitted from detonation, but I surely don't know everything.
Engine Basics: Detonation and Pre-Ignition by Allen W. Cline
I also found mention of chlorinated solvents and Ti valves being a possible problem. Not sure if your valves are the Ti or Inconel ones listed....
The valves did not look that way when new. In person it does look like they are blistered. I'll fool with them some more tonight. I'll also try and dig up some info on the valves. They were purchased a few years ago and I can't remember the details on them.
I would have assumed any chrome plating would have been applied to the valve stems, for wear purposes, because stainless is relatively "soft", tough but relatively soft, subject to galling. But that is just speculation on my part.There were no additives used. Engine was broke in on sunoco 110 and switched to E85. I got to scratching some of the "blisters". Comes off like a chrome plating. Competition products says they are 21-4N stainless. Chrome plating is used in the description so I can only assume thats what it is. Its hard stuff to scratch off. Thanks for all the replies guys.
I was thinking the same thing. Its dick hard so it must be some sort of coating lol
been there, done that on a 440 CI head. I tried epoxy, that didn't work. Had to have them welded twice, before that worked. No fun.I was cleaning up the valves and looking them over to maybe use in a new combo since they had so little run time on them. Wont be using them now. Had a little hydraulic issue with the old motor. I hit water when porting the heads so I epoxied it. From all my internet reading I learned that the ethanol probably softened the epoxy, it let go and leaked some water in the cylinder. Live and learn.
