71valiant
Make fast, break, repeat.
Wondering what kind of numbers you guys think this may put down. Its in a 67 Valiant. 295 rear tire with an 8.75 rear 3:91 with suregrip. Heads have been ported and polished.
Heres the link to the head work. http://www.forabodiesonly.com/mopar/showthread.php?t=180777
360. .30 over
Edelbrock Performer RPM intake manifold
Holley 650 DP
Engine Quest magnum cylinder heads, 62cc closed combustion chambers
10:1 compression ratio
2.02/1.60 Scorpion stainless steel intake/exhaust valves
Comp Cam beehive valve springs
Comp Cam 1.6 ratio adjustable rocker arms
Ross flat top forged pistons, Piston top .004 below deck, piston to cylinder head quench clearance .043 inch
Eagle SIR forged steel connecting rods with ARP rod bolts
Mopar cast iron crankshaft.
Heres the cam card.
360. .30 over
Holley 650 DP
Heres the cam card.
![x6bek7.jpg](http://i41.tinypic.com/x6bek7.jpg)
