usdart
Had to use a cutting torch to get the hub off cause the bearing was welded to the spindle. I just finished cleaning and grinding the spindle so the new bearing will slip on right again. It looks like I saved the spindle:blob:
Now I am waiting for the machine shop to sleeve the hub so the race fits tight again on the outer bearing.
Quite a MESS as you can imagine but, I am gaining on it:banghead:
