Wheel Cylinders...
nodemon
St.Louis
My new wheel cylinders came with a brass or copper washer in a little baggie.. There wasn't a washer anywhere I could see when I removed the old ones and lines.. Where's it go..?
Thanks..!
You got the brass ring... Free wheel cyls for life!
Sorry no help.
A wheel cyl typically has a hard line attached to it, front cyl might have a flex line attached directly to it and that's the only place I can see needing a crush washer.
Accident - most British and euro cars use a straight thread with a rubber line into the wheel cylinder and use the copper ring to seal.
