Wheel Stud Length
TNCUDA
Active Member
Nashville TN
Hey all
Quick question. anyone here running Cragar SS 14-inch wheels? If so, what stud length are you using? 1965 Barracuda 10" drums all the way around. going to run Cragar 14x6 SS mags
When I had a car with those wheels (SBP), the stock studs worked fine.
Bought a new set in 1979 for my 69 GTS and never changed the lugs. Still had left and right handed and used the lugnuts that came with the wheels...
Hey all
Do you have new ones, or "vintage"? The old wheels used mag lugs with a shoulder that went thru the wheel with a washer. Stock studs were fine.
The new wheels use special lugs available from cragar, (conical, with a shoulder) and the stock studs should be okay with the special lugs.
If you are running the stock 5 on 4 pattern, they use even more special lugs which are hard to find (smaller, thinner shoulder) and last I heard were backordered for months.
