Wheels and tires
Thee TMC
Member
Temecula CA
Good morning,
Anyone know what's the biggest wheels and tires I can run on a 65 valiant 200 stock suspension.
I had these made by Stockton wheel years ago.
15x7 small bolt pattern with 215 front and 225 rear.
Rears rubbed with 4 adults on turns and driveways.
Mine actually rubbed the upper inner fenders on the out side and not the lip.
IF you go with a 15'' small bolt pattern and have them made Do Not have them reversed.
Mine were Chrome Reverse like the old days. A standard 15x7 like the factory Chrysler wheel with a 4 1/4'' back space fit like a charm. I ran those on a 64 Dart(up graded to big bolt pattern) Tire size was 235 60 15.
I believe you can get 15''aftermarket steel wheels small bolt pattern thru Jegs or Summit.
View attachment 1715856640 View attachment 1715856641
Got it, no deep dish or fat lip
Standard lip it is
Appreciate it
I run 205-70R14's on stock 5.5 rims. Plenty of clearance. Probably another size up from that. Pinch point is inner side before you hit the springs . Can't really roll the fenders but you can delete the trim lip and bend it up at a few points. Larger diameter tires approach the front corners, use 1/4" - 1/2 spacers at front hanger to move it back 1/4 and keep your driveshaft the same.
No dumb questions here. A bodies have a 5 bolt with a 4'' bolt circle like your 65.
That was from the early 60's to 1973 when they went to disc brakes that shared with the B bodies of that date.
5 on 4 1/2 bolt circle .
Chrysler also did disc brakes from around 1967 to 72 in small bolt pattern.
Now after 1973 A bodies that still had drum brakes had small bolt pattern till 1976.76 being the last year for the A body.
Thank you
I came across a ‘73 Duster that had factory front disc brakes big bolt pattern and 10” rear drums with small bolt pattern, it was early production. It came with a small bolt pattern spare .
Makes you wonder what we’re they thinking .
I have installed ‘73 - ‘76 front disc brakes with big bolt pattern my ‘66 and at the moment have small bolt pattern 9” drums on the 7 1/4” rear axle . I have a 8 1/4” rear axle with 10” brakes big bolt pattern ready to go in . Of course this means a new driveshaft also .
I have the 73 disk brake front with BBP and a 7.25 rear with BBP. Running 225/60/15 all around. Only problem was the front which I fixed with a torsion bar adjustment. Unfortunately I buggered up the lower front fender dogleg on each side from several tight turns. Looks to be an easy fix.
