Where did you put the fuel pump with the stock tank?
67gtx
pomona, ca
Where did you put your elec. fuel pump with a stock tank? We're using BG220.
i am running a holley blue, and i put mine on the frame infront of the pass. side front leaf spring mount. (1973 duster) it was easy to splice int he factory fuel line then.
Ran 2 Holley blue pumps on my old '69 Dart 340 racecar. Had a rear-sump stock tank so mounted the pumps further back on narrowed frame (narrowed a bunch because I was running 14x32 slicks inside tubs with stock-height but 4" lengthened rear wheel wells. 1/2"-dia. fuel line then run forward along 2"x4" frame ties to fuel pressure regulator.
