Where do I find these
nitrohemi
mountville pa
anyone know where to find these little nylon things to attach the rear inside trim around the window on a fast back. Also do do you install the glass before you put the trim on?
If you cant find any, the part looks like a good candidate for 3D printing. Hit me up if you have a good OE part to copy from. I solid modeled a part for my dart and it came out awesome. I made 25 of the parts for about $45.00, so about $1.80 each. Don't know how long they will last but I have 23 extras!
I have a full set. BUT i'm not in town right now. I can get back with you on next Wed.
Many years ago, I needed just one for the below the sail panel area in a notch back. I found a simple flat plastic nutsert that would fit the same opening. Glued a piece of tubing, bottle cap or something centered at the hole on the back of the trim panel to get the stand off height.
Factory workers didn't need a flashlight and fiddle for hole alignment though.
There are different depths of those depending on year and model, if you did not get fixed up yet PM me i have various sizes available
