Where does this condenser Go own the back of the insturment panel
hippy 60
Lansing,N.C.
View attachment 1715169853 I took it off can't remember where it hook's
From an old 64 instrument panel, I think it goes on the 12v line from the ignition switch to the voltage limiter. So if you have the voltage limiter in the fuel gauge, it would go on that stud from the 12 volt source.
This is one a 63 Valiant forgot to put on here Thanks it's been Aug. since i have worked on it been sick bad heart
Electrically this is correct. One of the three gauge studs is 12V which is power going into the voltage limiter unit in the gauge
Second of the three is the output of the limiter internally, which feeds "out" to the other gauges
Third stud goes to the sender.
