Where to buy new a/c lines
BWDart
New Braunfels TX
Tryin to find new lines for 93 dodge ram van
leakin at dryer can't get them to seal tried double gskts
nobody local carries them
Where can I get them?
Thanks
Bruce
A photo would help. Never seen gaskets at a filter drier on a Mopar, just metal-metal flares on old ones or O-ring fittings on newer, but not at expert. Normally the metal tubes can be re-used, with new rubber hose installed. You might have to cut off the metal crimps w/ hacksaw & cutoff wheel, as I have done on several cars.
Ya it has the metal flare gskts thats where its leakin the hose part doesn't leak don't have any off the van to get pics it held up till 3rd can of refrigerant then started leakin tried a new dryer no change
Added a pic of dryer it leaks on both sides
Those block style hose ends are a son-of-a-gun to get sealed when they leak. As far as I know you can't buy new ones. I couldn't find any & was told they warp over time :BangHead:
Ended up drilling & clamping mine like this...Not pretty, but it works!!
Could also fix the problem for good by just fetching a "Tube-O" (O-ring seal) filter-dryer and having new lines made up locally.
