Ignition run feeds the warning lamps and gauge power in the instrument cluster, but IS NOT FUSED. If you tap into that, add an inline fuse. That line does not go through the fuse box. "Dark blue" goes directly from the ign switch to the bulkhead connector, and y's off to the cluster.
Otherwise, something "switched accessory" such as the AM radio connector
