which cam?
SRT_DSTRHOLC
"There is never enough horsepower...."
California
Im going to be running the magnum heads and i wanted to know what cam to run. Xe274 or the 268. On Camquest it showed that the 268 made more torque and at a lower rpm, while the 274 made about only 10 max more hp and the heads will be ported later so im wondeing what i should do becasue i saw that mancini racing does offer a magnum head spring that will handle .525 plus up to 600 so im not that worried about the springs jsut want the best cam. More torque or HP
OUCH! Huge lack of info here. Start by describing the car and it's intended purpose.
Where do you want to cruise at on the Hwy.?
Compression?
If you are worried about making the cam last, buy the recommended springs from the manufacturer.
o sorry guys
10.7 compression 360
kb107s
street and strip i want to run mid 12's
will be running 4.10 gears
Might I suggest a Lunati 60403 Cam? (Summit Link)
Cam Style: Hydraulic flat tappet
Basic Operating RPM Range: 1,800-6,200
Intake Duration at 050 inch Lift: 226
Exhaust Duration at 050 inch Lift: 234
Duration at 050 inch Lift: 226 int./234 exh.
Advertised Intake Duration: 268
Advertised Exhaust Duration: 276
Advertised Duration: 268 int./276 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.494 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.513 in.
Valve Lift with Factory Rocker Arm Ratio: 0.494 int./0.513 exh. lift
Lobe Separation (degrees): 110
I have this in my 340, with nearly identical specs and it makes awesome power.
You migiht even want the step above, 60404 Cam (Summit Link)
Basic Operating RPM Range: 2,200-6,400
Intake Duration at 050 inch Lift: 234
Exhaust Duration at 050 inch Lift: 242
Duration at 050 inch Lift: 234 int./242 exh.
Advertised Intake Duration: 276
Advertised Exhaust Duration: 284
Advertised Duration: 276 int./284 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.513 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.533 in.
Valve Lift with Factory Rocker Arm Ratio: 0.513 int./0.533 exh. lift
But I can't guarantee it will clear the heads with that much lift.
That one might work a bit better with your gears and compression though. (I have 10 to 1 Compression)
