Might I suggest a Lunati 60403 Cam? (
Summit Link)
Cam Style: Hydraulic flat tappet
Basic Operating RPM Range: 1,800-6,200
Intake Duration at 050 inch Lift: 226
Exhaust Duration at 050 inch Lift: 234
Duration at 050 inch Lift: 226 int./234 exh.
Advertised Intake Duration: 268
Advertised Exhaust Duration: 276
Advertised Duration: 268 int./276 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.494 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.513 in.
Valve Lift with Factory Rocker Arm Ratio: 0.494 int./0.513 exh. lift
Lobe Separation (degrees): 110
I have this in my 340, with nearly identical specs and it makes awesome power.
You migiht even want the step above, 60404 Cam (
Summit Link)
Basic Operating RPM Range: 2,200-6,400
Intake Duration at 050 inch Lift: 234
Exhaust Duration at 050 inch Lift: 242
Duration at 050 inch Lift: 234 int./242 exh.
Advertised Intake Duration: 276
Advertised Exhaust Duration: 284
Advertised Duration: 276 int./284 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.513 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.533 in.
Valve Lift with Factory Rocker Arm Ratio: 0.513 int./0.533 exh. lift
But I can't guarantee it will clear the heads with that much lift.
That one might work a bit better with your gears and compression though. (I have 10 to 1 Compression)
