which carb?
daredevil
S/w Houston
I have a dilema. I cant figure out which carb I want to use. The Newer Dominator is race prepped with aed linkage and stage 2 prep from diamondback. The older one with orange metering blocks works fine but is,nt as trick as the newer one. I really like the old school cloverleaf velocity stacks though. whats your choice?
They both look mighty fine,I,d go with whichever one works,responds best on the beast!Will you be running a airbreather on top?
What's your combo?
If you have both, I'd run them each at the strip and see which one gives the most mph on the slip.
Nice dilema to have BTW. :)
500 stroker 10.5 to 1 .575 lift solid roller 262 duration @ .050 indy ez heads ported. will probably run a velocity stack with a filter on dry days and when airs clear i,ll run nothing. No dusty dirt roads for me.
