Anything bigger than a 360 in a streeter is overkill.
With 3.55s, I cannot even floor it in the first two gears without tirespin, all the way to 50/60 mph.And that is with big tires. If your car is tire room challenged, a hot 318 would be fine, or a small-cam warmed up340, or a stock Magnum 5.9.
For me, it has to be a V8; I just never could get used to the bland; thoop-thoop-thoop, slanty idle.
Matty if you need a cat for smell control IMO, yur tune is off, and the cat is not gonna last long.
I have had SBMs since I turned 17 in 1970,nearly five decades ago, and the only ones that smelled were the oil-burners. Even the 292/292/108 cam can be tuned to idle pretty smell-free in a tight engine, which is the hardest area to clean up. With a modest cam of say 220* and optimized Q/compression, your SBM at 700/750 rpm,should be stink-free out the tailpipe; and even 650 in Drive,lol.
