fastback383
I am going to be taking the 400 out of my Barracuda and sticking a freshened up 1969 383 in. Just a quick ring and bearing on it, cast pistons and all. Now , which heads should I use, I have the set of 906's off of it and I have a set of 452's. I know the 452's have the hardened seats in it. But, I also have a set of Mopar Performance valves to put in them. The 2.14 intake and 1.81 exhaust. If I put them in the 452's do I lose the advantage of the hardened seats. I have been told as soon as they open up the exhaust seat to accept the bigger valve the hardening is gone. Is this true. I also plan on using the MP porting kit on the heads. I have also been told using the bigger valves on a relatively stock 383 without alot of compression ( its around 10-1 I am guessing ) may slow it down. It will lose some bottom end torque ? Am I going to be wasting these valves and some cash here ? Should I just port the 452's and forget about the bigger valves ? Has anyone here had any experience with this particular setup ? Any and all replies appreciated. Thanks, Dave aka fastback383.
