Which intake for AC
vntned
Gibsonville NC
Will a LD340 intake clear the factory AC on a SBM, or do I need a stock iron intake?
I believe the LD's will work with factory a/c. I know the LD4B's do.
It may depend on the A/C compressor. Didn't they change compressors in the later '70's which required the thermostat housing to be offset on the intake?
an old timer told me that the LD340 intake was just an aluminum version of the 1970 340-4 Intake.
I just bolted an RPM Air-Gap intake to my wifes 75 Duster 360. The bosses for the factory A/C compressor lined up (it was taped for a smaller bolt which was no biggie) and clears under the hood with a Holley 650 & oem air cleaner.
Absolutely yes! I have a LD-340 intake on my 360 69 Dart with the factory RV-2 compressor on it.
