" .. which ones work better .."
mopar66
which header gaskets seal better ..
percy # 66037 or remflex # 6003 ? ?
thanks
... and how many of you go with the philosophy of cutting the header flanges between 1-3, 5-7, 2-4 and 6-8 for better sealing ? ?
thanks
thanks
I never even heard of this methodology, but I can see where it might be advantageous if the flange or head isn't perfectly flat.
Curious to hear who has done this...
thanks
I k ow guys that swear by the method. I've never had to do it. I've run hookers, headmans and Tti and never had a problem sealing them at the head.
I have Percy's on the Duster. They work great. As far as cutting flanges.
Isn't 3-5 on the same flange and 4-6 also. Don't get the 1-3& 5-7. 2-4&6-8.
I can see cutting the whole flange asm between the outer ports and the
center ones so to cut down the chance of leaks if it's warped.
briankaplan ..
" .. I can see cutting the whole flange asm between the outer ports and the center ones so to cut down the chance of leaks if it's warped .."
that's what it means
thanks
i havent used remfex, i am using percys dead soft aluminum now on my RHS headed 318 with TTI headers.. No leaks here. im a believer. lol
i used the same gaskets on my old iron heads with bent to hell rusted hooker headers. nothin could stop them from leaking. i installed the percys gaskets and it sealed right up...i think they both are a nice gasket.
Used Remflex,nice product.Percys,I sell a few,no complaints.An old trick with standard header gaskets.
