Daniel Moreno
Dodgedartdan
No A/C. Power steering, alternator, and water pump.
March kit $688.00 or The Beast kit $525.00.
Hey I have the same budget as you !With my budget, I would get neither. If I had the budget, I would go with the black set, because I cannot STAND bling.
It’s called “the beast”I’d got with the all black set. What brand is it?
As long as you are NOT running Fluidamper or any other brand that is thicker than OE that system will work.
If you are running a damper that is thicker than OE the only company I know of making a system just for the thicker damper is March Performance.
I’m running a pro street damper that is 1” thick ?
View attachment 1715652498 Xxxxxx
Anyone know the thickness of an OE damper?I just posted about this yesterday. You will not be disappointed with the CVF Beast set. Very good quality
CVF Racing Shout Out!
Thank you yellow rose! I’ll double check before I pull the trigger. I’ll let you know how I make out. Dan MI have two FD’s and two chicom FD’s and the FD’s measure 1 7/16 thick and the chicom knockoffs measure 1 1/2 thick.
I think your damper may be thicker than OE but thinner than the FD. I just spent have an OE damper to measure.
a little well placed bling is okay in moderation, but by far the worst kind of bling is the Mr. Potatohead billet crap, which is what comes to mind when I see these setups. I do, however, like the black version. Makes it look much less Potatohead.
