I degreed it in and it wanted to be straight up. I retarded it back from there.So you installed it straight up? I assume the manufacture wants it installed 4 degree advanced
Cley
That is true, but car still went 93 in the Eighth, with the tach stuck on 7000 pretty much the whole way.Way more bottom end than the chassis can deal with ? Nonsense . You just don't have the proper tires.
That is true, but car still went 93 in the Eighth, with the tach stuck on 7000 pretty much the whole way.Or enough chassis.
Are you working on your street Duster or the new drag car?I degreed it in and it wanted to be straight up. I retarded it back from there.
Cley
To get extra CCP, you gotta steal it from the Power-Stroke;
We know. You say that in every thread. Ok not every thread but almost every thread. And it gets 32mpg US. We know. And it goes sideways every time you turn a corner. We know. And it runs 180psi on full timing on 87E10. WE KNOW!!That is true, but car still went 93 in the Eighth, with the tach stuck on 7000 pretty much the whole way.
and it does all of that on 25yr old wires, cap, rotor, plugs and tires!We know. You say that in every thread. Ok not every thread but almost every thread. And it gets 32mpg US. We know. And it goes sideways every time you turn a corner. We know. And it runs 180psi on full timing on 87E10. WE KNOW!!
This is in my street car.Are you working on your street Duster or the new drag car?
Like you said, it's an education that you pay for with just a gasket and some time... and "trial and error". i have played countless games like that. Had we had "internet" and "forums" back then, I'd been butchered like and Easter HamThis is in my street car.
Cley
And it has 100,000 miles on the same plugs and a yellow top accell coil from 1913.and it does all of that on 25yr old wires, cap, rotor, plugs and tires!
them BFG's must be made of magic to still be around after that kind of use!
Isn’t it fun?!?Man, this simple question is asked really went cow **** didn't it!
Cley
All I see on the gear is the 0 mark which is probably straight up and the triangle mark, I don’t see a third symbol and am wondering how you know if it is advanced or retarded it 4? Ie: is the triangle retarded or advanced? If you finitely knew which one the triangle is you can use the process of elimination to determine which is advanced or retarded…
I didn't think so. I think guys are trying to make sure you don't make a mistake you'll regret is all. I guess if that's your definition of ****, then so be it.Man, this simple question is asked really went cow **** didn't it!
Cley
I guess you missed the part about the car being on the 5th set of tires from 1999 to 2005 or so..and it does all of that on 25yr old wires, cap, rotor, plugs and tires!
I guess you missed the part about the car being on the 5th set of tires since 1999.
You know. It's an age old story. Once you LIE you have to keep lying to try and cover it up.ah, changing the story again to meet your narrative. no surprise there. carry on.
