1. if you follow the various mopar forums people post these kind of results all the time. There has been enough magazine articles where back to back coparisons have been done that show the results too.
2. The 360/380 (which actually dynos in the 400-420 range) has 230/234 @ 50 .508 lift cam. The MP 360/360 (which dyno in the 360-380 range) LA crate motors used the 284/284 241/241@50 .484 cam. Magnum has a lift advantage and the LA has a significant duration advantage. They both came with M1 intakes so the only other contributor is the heads. Just can't see where the roller cam in this situation is providing any advantage.
3. In the dyno challenges the competitors are assessed penalty points for spending money on aftermarket parts and there is no penalty for using factory parts. The game is can I make enough more power with an after market part to offset the penalty. Either magnum or LA heads are factory parts so there is no penalty to using either. For all of the competitors that went with factory parts to choose the magnum head would tell any reasaonble person that the magnum head has an advantage over the LA head.
4. According to the Hughes web page the LA head used was a 576 casting with 2.02 intake valves. The 576 casting was an MP head released as a replacement head for the 340 that was legal for Stock and Super Stock racing. They were even available drilled to accept offset rocks for TA motors. Hardly a smog casting and certainly a fair comparison.
Have no idea what you are trying to say here. Measuring flow through a cylinder port is a straight forward process. You maintain a constant pressure drop across the port (typically 28" of H2O) at each valve opening setting and measure the flow going through the bench. They way the flow is actually measured can vary; orifice plates, pitot tubes, anemometers, etc can all be used to measure the flow. All of these measurement methods have advantages and disadvantages and is a big part of the reason that tests done on different benches have such a wide variation in results. The really only way to compare numbers is for tests done on the same bench.
1. magazine shmagazine, they are looking to sell and advertise, and with the help from the westech bunch, yeah thats realistic.....
2. You aren't being honest here, if you were, you would have fessed up to the 1.6 rocker arms that are 'stock' on a mag'n'em head, so out with the few degrees of duration on the LA 360 to 'make it fair' crap. BTW it's time at max lift with a roller compared to the nano second of max lift on a flat tappet.
3. the head hughes used were not 576 heads they were 596 heads=smog heads that I would not use due to the short turn being different than what I like to see, yes there were differences , most don't really know this and just read about it.
4.Flow values, research it sometime, or better yet...talk to a local with a flow bench 'who has experience'.
What flow without port restriction=the flow value
The actual port flow #'s reflects how much test flow is actually flowing through the port itself, as the port reaches 90% of the flow value with increase in lift, you then increase the value/flow control knob.
A port could never see the the 90+% till it's lifted way past the reasonable typical amount of lift. You could show crummy flow easy if you wanna push it to the 90+% and make the low/mid lift numbers look like crap.
some operators will lift the valve .050 in increments only gaining 1-3% for .200 of the lift range, instead of just upping the flow value when the % flowed slows way down and is realistically not gonna get the desired 90+% of the value, that show as poor numbers, and in some examples rightfully so, but others like ones the creep at 80-85%...just up the value already.
last set of heads that I had flowed used 2-4 values of 74.1,153,303 on the int. and where form .350 to .450 only picked up 10%, and only 3% in a .050 [.4-.45lift increase, should or could of raised the value @.400 and had better numbers but didn't.
Someone who should chime in is Brian from IMM, he knows a lot more about flow bench than you or I.
He can tell you about plugs and plug removal in relation to flow value increase and at what percentage he raises it at or if he does raise it when the % port flow vs test flow lags/slows.
straight forward, not so much....there are tricks, like cnc'd radiused fixture plates and more...
