Who Sells Viscous Fan Hubs
Heating / Cooling / AC
  1. George Greene
    George Greene Active Member
    36
    27
    Feb 9, 2020
    Nicholasville, Ky.
    Local Time:
    4:35 AM
    Who sells correct 1971 Viscous Fan Hubs that you guys like? Are the ones at the parts stores the OE style? Or are they “will fit”?
    Thanks
  2. halifaxhops
    halifaxhops It's going to get stupid around here! FABO Gold Member
    59,219
    27495
    Jan 20, 2014
    CENTRURAL, PA
    Local Time:
    4:35 AM
    Do a search on them there was a great thread a while ago on them.
    • Like Like x 1
    • Steven190
      Steven190 FABO Gold Member FABO Gold Member
      1,128
      554
      Jan 13, 2012
      Omaha
      Local Time:
      3:35 AM
      The Hayden's work, I think that they made them for the factory
    • George Greene
      36
      27
      Feb 9, 2020
      Nicholasville, Ky.
      Local Time:
      4:35 AM
      Thanks. The Hayden’s, is that a brand or a seller?
    • Steven190
      1,128
      554
      Jan 13, 2012
      Omaha
      Local Time:
      3:35 AM
      A brand any good auto parts sells them, even Jeg's and Summit
      I have used #2765 and 2947, They are the shorter ones, or they can match your application.
      • Agree Agree x 1
      • diymirage
        diymirage HP@idle > hondaHP@redline
        19,083
        12912
        Oct 12, 2012
        michigan
        Local Time:
        4:35 AM
        did they make the one for the Jag that also works?
      • Steven190
        1,128
        554
        Jan 13, 2012
        Omaha
        Local Time:
        3:35 AM
        Yes that is I believe the 2765
        • Thanks! Thanks! x 1
        • 383Scampman
          383Scampman Well-Known Member
          1,627
          835
          Nov 24, 2013
          New Hampshire
          Local Time:
          4:35 AM
          Hayden short
        • chrisf
          chrisf Well-Known Member
          575
          36
          Sep 15, 2004
          Local Time:
          9:35 AM
          tony's parts sells a 070 reproduction its on his site.
          • TrailBeast
            TrailBeast AKA Mopars4us on Youtube
            21,329
            8846
            Mar 11, 2011
            Arizona
            Local Time:
            1:35 AM
            Hayden is the brand.
            I read somewhere Hayden made one specifically because of the limited room.
            #2947 as Steven190 posted.
            Here we go.
            • George Greene
              36
              27
              Feb 9, 2020
              Nicholasville, Ky.
              Local Time:
              4:35 AM
              I ordered a Hayden OE from KOI, Heavy Duty Thermal. We’ll see, thanks guys.
            • George Greene
              36
              27
              Feb 9, 2020
              Nicholasville, Ky.
              Local Time:
              4:35 AM
            • DartGTDan
              DartGTDan 70-71 Dart GT Fan
              1,069
              871
              May 29, 2004
              Detroit Metropolitan Area
              Local Time:
              4:35 AM
              Does anyone know what comes with the Mopar Performance Viscous Fan package? How tall/short is the one in that kit?
            • famous bob
              famous bob mopar misfit FABO Gold Member
              16,597
              6377
              Aug 14, 2011
              okla
              Local Time:
              3:35 AM
              N
            • str12-340
              str12-340 FABO Gold Member FABO Gold Member
              1,036
              560
              Dec 26, 2012
              Vashon, WA
              Local Time:
              1:35 AM
              If you don't mind taking out your radiator every time you need to take off the water pump it's fine!!! I put one on my 340 while it was out of the car. It went in fine and the radiator went in fine, but a year later when I needed to change the water pump, I couldn't get the fan off without buggering up the radiator because the fan was so close to it. When the new Hayden short shafts came out I swapped it over. Live and learn...
            • DartGTDan
              1,069
              871
              May 29, 2004
              Local Time:
              4:35 AM
              That is exactly what I'm experiencing. I have between 1/4" & 3/8" between the radiator and the fan blades. Do you know which Hayden short shaft you used?
            • Steven190
              1,128
              554
              Jan 13, 2012
              Omaha
              Local Time:
              3:35 AM
              You need about 3/4" between the radiator and fan. I think that the 2947 is the shorter one.
              • Like Like x 1
              • DartGTDan
                1,069
                871
                May 29, 2004
                Local Time:
                4:35 AM
                Will the fan being that close to the radiator not cool as well at highway speeds? It seems to stay at 195* in town but highway cruising the temperature has climbed to ~230*.
                I installed a new replacement Spectra Premium cu5526 radiator, 6-vane water pump, MP viscous fan kit, added the Detroit Muscle Technologies hood to radiator support seal, new upper and lower hoses (with the spring in the lower), and yes I'm using the factory shroud.
              • George Greene
                36
                27
                Feb 9, 2020
                Nicholasville, Ky.
                Local Time:
                4:35 AM
              • str12-340
                1,036
                560
                Dec 26, 2012
                Vashon, WA
                Local Time:
                1:35 AM
                The Hayden Short shaft fan clutch is part number 2947. I went out to the garage today where I still have 2 on the shelf - you don't know when they will stop making odd stuff like this. By the way the Jag fan that many of us used to use fit better but it wasn't speced for a v-8 and many of them start breaking down early. It was a guy here on FABO that got Hayden to make these. We had a campaign to e-mail Hayden to show them the demand.
              • RustyRatRod
                RustyRatRod Bla de blizhibliz de blatde blizi bla bla FABO Gold Member
                60,795
                32447
                Jun 7, 2010
                Georgia
                Local Time:
                4:35 AM
                I find all this strange. I've run the MP fan setup in both early and later A bodies and have never had a problem with room. And yes, the radiator does have to come out on the early cars, but so what? It's a ten minute job. I caint believe anyone is crying about that. Take up stamp collecting maybe? Just kiddin of course, but dangit, radiator removal is way easy. If that has to come out for access to something else, then so be it. It's part of the job.
                • Agree Agree x 1
                • moparmarks
                  moparmarks FABO Gold Member FABO Gold Member
                  837
                  376
                  Oct 5, 2014
                  Western Colorado
                  Local Time:
                  2:35 AM
                  I used a cheap aftermarket aluminum radiator on my Dart and had to use the Hayden short shaft clutch which I bought last year from NAPA.
                • str12-340
                  1,036
                  560
                  Dec 26, 2012
                  Vashon, WA
                  Local Time:
                  1:35 AM
                  1 - the fan is too damned close to the radiator. to operate correctly. The original fan clutches were the height of the Hayden short shaft.
                  2 - if you have a minor front end accident there goes the radiator, and the fan (don't ask why I know this)
                  3 - Rusty, you must have some magic way to keep the antifreeze in the radiator and engine while performing this ""10 minute job". Please share it with us all.
                  • Like Like x 1
                  • yellow rose
                    yellow rose Doctor of Thinkology.
                    22,071
                    18143
                    Jun 19, 2015
                    Living on the razors edge
                    Local Time:
                    1:35 AM
                    Number 1 is incorrect unless you have a shroud and the fan is buried in the shroud. If that’s the case then yes, the fan is too close to the radiator.
                    • Agree Agree x 1
